Vlan routing
paul.matthews Wed, 09/26/2007 - 02:28
  • Silver, 250 points or more
Assuming a L3 switch
int vlan 10
desc ISP link
ip add
no shut
int vlan20
des ground floor users
ip add
no shut
int vlan 30
des basement users
ip add
no shut
int fas 0/1
des link to isp
switch mode acce
switch acce vlan 10
int range fas 0/2 - 10
switch mode acce
switch acce vlan 20
int range fas 0/11 - 20
des basement users
switch mode acce
switch acce vlan 30
ip route 0.0.0.0 0.0.0.0
will create two VLAN routing interfaces for users, allow routing between them, a third interface to the ISP, allow routing there for all unknown traffic. and put ports into those VLANs
Paul.
l.mourits Wed, 09/26/2007 - 02:55
Or, if you want a L3 interface instead, you may do this:
int fas0/1
no switchport
ip address
That way it really acts as a L3 interface (like a router).
HTH,
Leo
paul.matthews Thu, 09/27/2007 - 00:23
Defining the interface as an L3 interface, and assigning the IP address locally permits just that one interface in tthat subnet.
The use of an SVI means multiple iports can be in the same VLAN and routed.
Paul.
l.mourits Thu, 09/27/2007 - 00:25
As mentioned in my first reply ;-)
