Cisco 1812 wireles setup, can't get it to work
Sep 26th, 2007
Hello everyone,
I've read trough the "871 wireless setup" topic, which I found very helpful, but I still can't get my wireless working. Basically I have a Cisco 1812W and I would like both wireless and wired to be on the same subnet. We aren't using DHCP, so the IP's are all static (even for the wireless clients). I can connect to my wireless SSID, but ping doesn't go trough either way. Wired connections are working fine. So the wireless client is connected, but has no IP address as far as the router goes (show Dot11 associations shows it's IP as 0.0.0.0) , but the wireless client does have an IP set up.
I guess I'm overlooking something in my config, so here it is (i took out the firewall rules and aaa setup, they aren't relevant if i'm not mistaken and there's a limit to post size):
ip cef
ip tcp synwait-time 10
no ip bootp server
ip name-server <removed>
crypto pki trustpoint TP-self-signed-1358229530
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1358229530
revocation-check none
rsakeypair TP-self-signed-1358229530
crypto pki certificate chain TP-self-signed-1358229530
certificate self-signed <removed>
quit
username <removed>
bridge irb
interface Null0
no ip unreachables
interface FastEthernet0
description $ETH-WAN$$FW_OUTSIDE$
ip address extip extsubnet
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip inspect sdm_ins_in_100 in
ip inspect SDM_MEDIUM out
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
description 802.11g
no ip address
encryption mode ciphers tkip
ssid <removed>
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 <removed>
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
description 802.11a
no ip address
shutdown
encryption key 1 size 40bit 7 1ED10A3EC0C5 transmit-key
encryption mode wep mandatory
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
bridge-group 1
interface BVI1
ip address <internal router ip> <subnet>
ip access-group 100 in
ip nat inside
ip route 0.0.0.0 0.0.0.0 <external router IP> permanent
ip flow-top-talkers
top 5
sort-by bytes
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
<bunch of static nats>
<access rules>
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
access-class 102 in
password 7 <removed>
transport input ssh
scheduler allocate 4000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
AmadejBukorovic Thu, 09/27/2007 - 02:29
Okay, I've somewhat figured it out. Apparently my WPA-PSK configuration doesn't work with the integrated Broadcom adapter found in the laptop I was testing it with.
Either that or my WPA-PSK configuration is broken.
I switched over to an open network with no encrpytion and everything works now.
deanhjohnson Tue, 12/18/2007 - 06:38
I'm having a similar problem getting Broadcom adapters to connect with WPA-PSK on our 1240AG APs. Does anyone have any suggestions?
