Command to show SNMP version running on the router/switch
jacobss914 Fri, 09/28/2007 - 08:48
From that command you don't know you need to look for a command simular to this.
snmp-server host x.x.x.x version 2c public
This command is a version 2c
snmp-server host x.x.x.x version 1 public
And that one is for SNMP V1
If it is not present then you are sending in SNMP V1
Thorough explaination of SNMP:
