IPCC Backup strategy
Sep 26th, 2007
I have two IPCC in failover. Do I need to backup both or if a backup only the master?
Presently I am doing both and the tar files is around 22gig.
Abdulbaseer Mohammed Wed, 09/26/2007 - 21:29
  • Silver, 250 points or more
both is not needed if it is IPCC 3.x or higher. . You need your bars backed up well
if you really have a hot need then you need to go to enterprise.
