Factory reset a Cisco 877?
Sep 26th, 2007
Hi, I've messed up my config on my Cisco 877 and just want to reset it back to when I got it of the box, possible?
mannschaft Wed, 09/26/2007 - 07:15
hi
you can reset your Cisco877 to default constructor by puching the reset button between Consol and ADSL ports.keep the reset pessed until you see that the router had rebooted.and after connect using SDM on 10.10.10.1.
