ASA WebVPN License
Sep 26th, 2007
We had two ASA devices delivered( different specs) the WebVPN license has been installed on the wrong box, is it possible to remove it from the box it is currently installed on and install it on the correct box, if so how can it be done
Overall Rating: 3.5 (2 ratings)
Communications Wed, 09/26/2007 - 22:34
Hi Guys
Thanks for the feedback I was not sure if you could just copy/port the info from one box to the other?
Thanks Mike
