What is certified operating temp. for WS-X6708-10GE
Sep 26th, 2007
I couldn't fins any docs which describes the certified operating temp. for this module, and with "show env" the temp seems to be quite high.
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 45C
module 1 inlet temperature: 31C
module 1 aux-1 temperature: 47C
module 1 aux-2 temperature: 37C
module 1 asic-1 (SSA-1) temp: 66C
module 1 asic-2 (SSA-2) temp: 62C
module 1 EARL outlet temperature: 39C
module 1 EARL inlet temperature: 35C
Does anyone know the "limits" or is there a doc. with specification.
THX
Emanuel
e.hoehn Fri, 09/28/2007 - 01:44
Thx for reply. I already had this info.
I'm looking a spec. for the ASIC temp.
Is there any information available ?
e.hoehn Fri, 09/28/2007 - 02:13
unfortunately not.
Where you find the certified max operating temp. for ASICs. This also just says operating temp for the module itselfe.
I'm looking for the asic spec. 'cause they are running at over 60 degrees.
Ali Norouzi Sun, 06/22/2014 - 22:15
Did you find answer to your question about ASIC temperature threshold? How did you handle this issue?
