Traffic Flow
robert.c.davis4
Is there any way to manipulate the flow of traffic on a network?
It has become necessary for our campus network to have all traffic on port 80/443 go through a smart filter server. Due to the current set up of the network, access control lists would open too many bee hives to implement.
Is there any other solution to funneling this traffic down to through this server, and then out to the internet?
I know the question is broad, but I'm simply looking for ideas at this point.
(6500/4500/3550 switches)
Richard Burts
Robert
There is a feature named Policy Based Routing which allows your routing devices to forward certain types of traffic (which you specify) in ways that are different from the normal routing table. So you could identify any traffic that is TCP on port 80 or on port 443 and send them to a different next hop. I believe that this feature is the best solution for what you are attempting to achieve. What it would take to implement it and how well it would work could only be determined by someone who knew your environment.
Rick
Rick
Thanks for the idea. I will certainly look into it.
Ok, I actually found a few things that will really work. Thanks a bunch Rick!!!
