VPN and Satellite Internet
Sep 26th, 2007
Is this possible? I have a vpn connection currently w/ broadband internet. Moving to rural area. Can only get satellite internet. Is there one satellite internet service that is compatible with a vpn connection?
acomiskey Wed, 09/26/2007 - 05:47
  • Green, 3000 points or more
You'd have to check with each specific provider to see what they recommend.
One option is to use SSL vpn instead of ipsec.
khinze Wed, 09/26/2007 - 08:42
I have seen RA IPSec VPN using UDP work over satellite. I don't recall the Sat vendor / ISP though.
