Unity 5.x question
Sep 26th, 2007
Hope this is the right place. I have a need to create a caller input menu that has a couple of menu options that just plays informational messages (then hangs up). I am not sure how this is done. I know i can transfer to subscribers, or interview handlers, but I dont think thats going to work.
any suggestions?
Overall Rating: 4 (1 ratings)
Rob Huffman Wed, 09/26/2007 - 05:53
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Don,
You should be able to set up a Standard Subscriber mailbox and then just tweak the After Greeting Setting to Goodbye or Hang up;
After Greeting
Indicate the action that Cisco Unity performs after the greeting plays:
Take Message - Cisco Unity records a message from the caller. Click the Take Message link to view the Messages page.
**Say Good-Bye - Cisco Unity plays a brief good-bye, and the call is disconnected. Click the Say Good-Bye link to view the Good-Bye call handler.
Send Caller To - Cisco Unity sends the call to the destination that you select:
Call Handler - Sends the call to the call handler that you select.
Directory Handler - Sends the call to directory assistance.
Greetings Administrator - Sends the call to a conversation for changing call handler greetings over the phone.
**Hang Up - Disconnects the call. Use carefully; unexpected hang-ups can appear rude to callers.
Interview Handler - Sends the call to the interview handler that you select.
Sign-In - Sends the call to the subscriber logon conversation.
Subscriber - Sends the call to the subscriber that you select.
Hope this helps!
Rob
don.click1 Wed, 09/26/2007 - 06:00
So, in order to have the option to just play a message, will need to create a new voicemail subscriber? is there no 2nd choice? For this particular application, i already have 3 voicemail subscribers, a call handler and a interview handler. Thanks for the info, tho.
mchandak Wed, 09/26/2007 - 06:08
  • Gold, 750 points or more
To add to Rob's Notes, I'd recommend using a Call Handler instead of using CallHandler instead of Subscriber and rest would be the same as Rob as mentioned.
Hope this helps
Rob Huffman Wed, 09/26/2007 - 06:24
  • Hall of Fame,
    Founding Member
Hi Don/Mahesh
Sorry guys ....my reference was only to "how to setup an "Informational Mailbox" that does not take any messages. When you press a Key for different menu choices (from a Call Handler) this has to route to either a Subscriber, Directory Handler,Interview Handler or another Call Handler. Perhaps I misunderstood the question (not the first time :)
Take care,
Rob
