09-26-2007 06:57 AM - edited 03-18-2019 07:52 PM
I have installed CM 5.0(4) at a customer site, initially when i installed the AC the status were showin fine, but afterwards they showed unknown for all users. Tha AC service is started on the servers. Please HELP!
09-26-2007 07:50 AM
Hi Joy,
Have you tried stopping and starting Cisco TCD (Telephony Call Dispatcher) service?
Rob
09-26-2007 11:51 PM
Hi Rob,
Call Manager 5.0(4) doesnt have the TCD service. Only the Attendant Console service which i have tried stopped and starting, but it doesnt help.
Joy
04-16-2008 10:21 AM
did you ever find out what was causing this issue? I seem to be running into it for the first time. Everything else is working with no problems. Just line status of in directory window is showing up as unknown.
04-16-2008 10:34 AM
Unfortunately am still having this issue, trying to sort it out with the help of Cisco TAC. Though i had a couple of suggestions that may work in your case:
1. Check whether there's a firewall between the call manager and the attendant console pc, to resolve this you can have have 2 NICs on the AC pc with one NIC in the same subnet as the call manager. With this option you'll need to specify the ip address it should use for the line status on the AC settings on the PC.
2. Or check the ports the line status is using to send the updates, maybe they're blocked by the firewall.
Hope it helps. If it doesn't i'll let you know what we'll come up with Cisco TAC.
Cheers!
04-16-2008 10:36 AM
Already checked on all that. Let me know what TAC comes up with. Thanks!
04-16-2008 03:55 PM
are the DN's you have in CUCM the same ones that you have in the directory?? i mean that the phone has DN 1000 and the directory also shows DN 1000 for the user associated with the phone??
i ask because i've seen some cases in which the real DN of the phone is 1000 but since there are several offices with overlapping they added a prefix into the directory and it showed up as something like 21000, if that's the case that's why you do not get the status
the DNs need to match to see the right status
javalenc
if this helps, please rate
