1130AG Lightweight IOS V12.(7)JX - static ip on it can't removed
Sep 26th, 2007
Hi there - I'm stuck on this problem... my 1130AG lightweight access point has and static ip address on fa0
AP0007.0e5f.f430#show ip int brie
FastEthernet0 10.40.0.1 YES other up down
I want to clear the ip address so I can put it on the network and have my WLC find it. I tried everything with no success. I read the clear command, but it doesn't give me the option that some cisco documents have. does anyone know how to clear that address?
Thanks!!!
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 09/26/2007 - 07:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mauricio,
Have you tried this method?
Clearing Manually Entered Controller Information
When you need to move your access point to a different location in your network, you must clear the manually entered controller information to allow your access point to associate with a different controller.
Note This command requires the controller-configured Enable password to enter the CLI EXEC mode.
To clear or remove the manually entered controller information, you can use these EXEC mode CLI commands:
clear lwapp ap ip address
clear lwapp ip default-gateway
clear lwapp controller ip address
clear lwapp ap hostname
Manually Resetting the Access Point to Defaults
You can manually reset your access point to default settings using this EXEC mode CLI command:
clear lwapp private-config
From this doc;
http://www.cisco.com/en/US/products/ps5861/products_installation_guide_chapter09186a008072151f.html#wp1076073
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
