booting error
Sep 26th, 2007
I have a problem during booting of a 7206 npe-g1.
I've used this router since last week. I turned it off and today i received this error that it hasnt done before:
Readonly ROMMON initialized
Self decompressing the image : ########################################################################## [OK]
Error : compressed image checksum is incorrect 0x4C4E2D85
Expected a checksum of 0xF68F226A
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x8000eb60
PC = 0x00000000, SP = 0x00000000, RA = 0x00000000
Cause Reg = 0x00000000, Status Reg = 0x00000000
System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
C7200 platform with 1048576 Kbytes of main memory
string is disk2:c7200-p-mz.124-10a.bin
Self decompressing the image : ####################################################################################################################################################### [OK]
inizially the router gave a checksum error but then it starts ios.
I tried to change ram, format flash and also to download a new ios, but always the same problem.
Any advice to solve the problem?
Thanks in advance,
Milko
