bridge-domain vs bre-connect
Sep 26th, 2007
Note: I didn't find an ATM Forum.
- What will be the difference between bridge-domain and bre-connect?
- Which one should be pursued for the migration path of ATM PVCs to VLANs at MetroEthernet?
- Which will be easier for the integration of ATM internetworking over MPLS to ME?
-W
Overall Rating: 4 (1 ratings)
didyap Wed, 10/03/2007 - 11:37
  • Silver, 250 points or more
If the design does not necessarily include a Cisco CPE which can support bridge encapsulation over the ATM PVC ("atm route-bridge ip") in that case you can use "bridge-domain" rather than "bre-connect". If the service design includes non-Cisco DSL CPEs which do not support bridge encapsulation in that case you have to use "bre-connect". In any case, Cisco or non-Cisco, the CPE is a ROUTER meaning it has a LAN IP address and a WAN (DSL) IP address. Following links may help you
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a00801e5c05.html#wp1102246
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a008021ff14.html
