ajagadee Wed, 09/26/2007 - 10:33
  • Cisco Employee,
NETFlow is not supported on the FWSM. You could use the SUP on the Catalyst 6509 to do NETFlow.
Please refer the below URLs for configuration details:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/nde.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/nde.html
I hope it helps.
Arul
** Please rate all helpful posts **
nguyenvinht Wed, 09/26/2007 - 16:03
Thanks for letting me know. I wasn't able to get outbound netflow data from 6509 with SUP 720 because the ip of the gateway of the vlans is defined on the FWSM. In order to get netflow on 6509, each Vlan interface needs to have an ip address.
Vinh
