lgijssel Wed, 09/26/2007 - 22:07
  • Red, 2250 points or more
Could be a configuration issue. Are you sure that you have set the correct isdn switch type? I do not know what is used in the UAE.
regards,
Leo
smothuku Thu, 09/27/2007 - 01:47
  • Silver, 250 points or more
Please paste show isdn status output and config of both the routers.
satish
aalhousani Thu, 09/27/2007 - 04:03
Yes 100% sure about the configuration,
this is not the first setup I have configure, we have alot of same setup and configuration.
switch type in UAE is net3
gunner07971 Fri, 09/28/2007 - 01:52
Sounds like an IOS bug to me.
What version are you using on the router that generates the error message?
Cheers,
