DSPFARM status is DSPFARM_DOWN
Answered Question
Sep 26th, 2007
I can't figure out why a dspfarm on a 1760 is down and won't go up after I reconfigure it as follows:
sccp local FastEthernet0/0
sccp
sccp ccm 10.110.15.101 priority 1
sccp ccm 10.110.15.100 priority 2
sccp ip precedence 3
dspfarm transcoder maximum sessions 4
dspfarm confbridge maximum sessions 6
dspfarm
Have resources configured in CCM:
Cisco IOS Conference Bridge
CFB000dbceff9ec
Cisco IOS Media Termination Point
MTP000dbceff9ec
Can do an extended ping from the FE interface of the router to both CCM servers and vice versa.
Any advice is greatly appreciated.
Yefim
Correct Answer by Rajesh Revuru about 9 years 6 months ago
Just try changging it on CCM to Cisco IOS Enhanced Conference Bridge and MTP.
It worked for me
Overall Rating: 5 (1 ratings)
sadbulali Wed, 10/03/2007 - 13:42
  • Bronze, 100 points or more
Can you send the config of the router and possibly a screen shot of the DSPfarm setup fomr CM?
y-sapozhnikov Thu, 10/04/2007 - 13:33
I tried to configure another router using the same settings but to no avail.
Here is the pertinent show and config:
sanrtr01#sh dspfarm
DSPFARM Configuration Information:
Admin State: UP, Oper Status: ACTIVE - Cause code: NONE
Transcoding Sessions: 2(Avail: 2), Conferencing Sessions: 1 (Avail: 1)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
sanrtr01#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.10.252.1
Switchover Method: IMMEDIATE, Switchback Method: GUARD_TIMER
Switchback Guard Timer: 1200 sec, IP Precedence: 3
Max Supported MTP sessions: 0
User Masked Codec list: None
Call Manager: 10.110.15.101, Port Number: 2000
Priority: 1, Version: 3.1 or Higher
Call Manager: 10.110.15.100, Port Number: 2000
Priority: 2, Version: 3.1 or Higher
Packet Voice DSP Module Slot 0:
Hardware Revision : 3.2
Part Number : 73-6731-01
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : VIC09156XHF
DSP memory size(in kwords): 256
Type of DSP : TMS320C549
Product (FRU) Number : PVDM-256K-8=
Packet Voice DSP Module Slot 1:
Part Number : 73-6726-01
Board Revision : A0
Number of DSP's : 1
Product (FRU) Number : PVDM-256K-4=
sanrtr01#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 000 00 g711ulaw 9.4.0 Idle Idle 0 0 2/0 NA 0 498597/50595
7
C549 000 01 g711ulaw 9.4.0 Idle Idle 0 0 2/1 NA 0 29973/29766
C549 000 02 g711ulaw 9.4.0 Idle Idle 0 0 2/2 NA 0 0/22
C549 000 03 g711ulaw 9.4.0 Idle Idle 0 0 2/3 NA 0 0/21
Active Voice Call details
Current total analog signalling channels: 4
Current max allowed digital timeslot for voice: 0
Current active transcoding sessions: 0
Current free transcoding sessions: 2
Current active conferencing sessions: 0
Current free conferencing sessions: 1
Current number of DSP group: 1
Group 0:
Current allocated analog signalling channels: 4
Current free analog signalling channels: 0
Current allocated digital signalling channels: 0
Current free digital signalling channels: 0
Port(s) served: 2/0 2/1 2/2 2/3
Current Available MIPS: 300
SPMM DSPRM State Image D-sig D-sig A-sig A-sig Mips Voice/Xcode
Dsp Dsp allocate free allocate free Free Chan
0/0 0 UP FIXMC 0 0 4 0 100 0
0/1 1 UP CONF 0 0 0 0 100 0
1/0 2 UP XCODE 0 0 0 0 100 0
interface FastEthernet0/0
description **** Sandhills LAN ****
ip address 10.10.207.1 255.255.255.0 secondary
ip address 10.10.252.1 255.255.255.192
ip access-group 101 in
ip access-group 101 out
ip helper-address 10.0.15.246
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.10.252.1
service-policy output voip
sccp
dspfarm transcoder maximum sessions 2
dspfarm confbridge maximum sessions 1
dspfarm
Screenshots are attached.
Correct Answer
Rajesh Revuru Wed, 10/03/2007 - 14:14
  • Silver, 250 points or more
It worked for me
