can't access intenet usign cisco router 2620
Sep 26th, 2007
We configured cisco router 2620 to get access to internet initially. Then we will put a pix firewall inside of router.
We configured internal interface of router and out side interface of the router also. configure static nat as per documentation of CISCO web site.
Now the router can ping all interfaces of router, ISP gateway. can ping web address (i.e, yahoo.com).
But from the host that is connected thru a switch to the router inside interface can ping till outside interface of router but can't ping gateway of Service Provider, and can't go to internet.
I would appreciate help regarding same.
chjanoff Wed, 09/26/2007 - 15:13
  • Cisco Employee,
Hi Rejul,
This forum is for discussing PCI compliance. It sounds like you might want to open a TAC case to help verify your cabling and configuration. This is not the appropriate forum for your question. Regards,
Christian
