ACE HTTP Probe with regex
Sep 26th, 2007
I'm trying to setup a HTTP probe with expected string rather then a code (config below). I do a GET for the page then a search for a string in the response however it's not working, as probe appears as failed.
I've tested the connection to the server by using telneting and then looking at the page displayed to make sure the string I want to match is in the response.
probe http HTTP-PROBE
port 43050
interval 30
passdetect interval 30
passdetect count 1
request method get url /action=help
open 43050
expect regex action=help
Q. Is there anything wrong with this configuration and what I'm trying to achive?
Pritesh
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Wed, 09/26/2007 - 13:47
  • Blue, 1500 points or more
Use "expect status" under probe config. expect regex doesnt work if expect status is not configured.
expect regex work flawlessly with static pages. It doesnt work all the time with dynamic pages.
Specially if "content-length" header is missing from Server response.
Hope it helps
Syed Iftekhar Ahmed
zblajhani Thu, 03/22/2012 - 03:09
Can regex be done with this string?
ALL CHECKS OK
i get an error when configuring this string
