ASA 5510 and ASDM no longer shows config
Sep 26th, 2007
ASA 5510 V8.0(2)
ASDM V6.0
Whan I launch ASDM and then choose the configuration tab it no longer show me the configuration it just shows the start up wizard screen. This just broke as it was working fine and I could see and use everything under configuration. Anyone know what happened or what is going on?
JORGE RODRIGUEZ Wed, 09/26/2007 - 16:50
  • Green, 3000 points or more
If you telnet to asa is the configuration still there? try loading asdm from another system.
jeff.vargas Fri, 09/28/2007 - 06:07
Yes, the config is still there. I'll need to track down another system to see if the issue is specific to this box.
jwalker@swinc.com Tue, 10/02/2007 - 13:31
  • Silver, 250 points or more
Did you make any new changes to the config? I know that in PDM certain unsupported commands would render PDM useless. Until you deleted the unsupported command via CLI, PDM wouldn't work.
