2003 Microsoft IAS Radius with AAA configs
Sep 26th, 2007
Radius AAA works great until I have to change my windows password
(ie every 180 days). After changing password, I cannot access routers or switches.
The workaround is to reset my password back to the original password.
How do I get around this?
gmarogi Wed, 10/03/2007 - 18:08
Send the following information from your IAS server to proceed for further troubleshooting.
1. Are you using any 802.1x/EAP authentication?
2. Send me the router/switch configurations relevant to AAA
3. Capture debug aaa authentication on your router/switch and send me the entire debug output captured. Based on that only, I can understand what is actually happening during the failed authentication.
Jagdeep Gambhir Fri, 10/05/2007 - 11:41
If you are using telnet then that is not supported as telnet uses PAP and password expiry is not supported by PAP (we need mschapv2)
.RADIUS-based Windows Password Aging-Users must be in the Windows user database and be using a RADIUS client/supplicant that supports changing passwords by using Microsoft-Challenge Authentication Handshake Protocol (MS-CHAP).
You can use this to change your password,
http://www.greyware.com/software/domainpassword/
Hope that helps
~JG
Trending Topics - Security & Network
