PIX Routing
Sep 26th, 2007
I am a Cisco Newbie so thanks in advance for all help.
I need to set up the firewall to allow our software support company in via rdp.
I have the IP Address of the server they are connecting through, and I have a public address that I think i need to NAT to our servers internal address...
I have both command line access and gui access so all advice would be great.
Thanks Stephen
JORGE RODRIGUEZ Wed, 09/26/2007 - 16:46
Stephen, if you have available public IP for the static NAT, do as :
Your local LAN server: IP 192.168.10.10
Your availble public IP : 10.20.30.40
create static nat for local server
e.g
static (inside,outside ) 10.20.30.40 192.168.10.10 255.255.255.255 0 0
create access list to allow traffic , for example RDP
access-list outside_access_in permit tcp any host 10.20.30.40 eq 3389
access-group outside_access_in in interface outside
Jorge
