ASA ssh access issue
Sep 26th, 2007
I'm trying to establish remote access to my ASA; I can ping it, but telnet and ssh both are refused immediately. I know that Telnet isn't allowed into an outside interface, but ssh still doesn't work (I've already generated an rsa key, also).
This device has an inside network, DMZ (unused) and two outside networks; see below for relevant config lines:
ASA# sh run
interface GigabitEthernet0/0
description FLR FIBER LINK
nameif flr
security-level 50
ip address
interface GigabitEthernet0/1
description SFCC LAN
nameif inside
security-level 100
ip address
interface GigabitEthernet0/2
nameif DMZ
security-level 0
no ip address
interface GigabitEthernet0/3
description TEMP 10MB INTERNET
nameif sfcc
security-level 50
ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.xx.xx
global (sfcc) 1 interface
nat (inside) 0 access-list
nat (inside) 1
route sfcc (next hop)
http server enable
http flr
http inside
http management
http sfcc
telnet flr
telnet inside
telnet inside
telnet sfcc
ssh flr
ssh inside
ssh sfcc
management-access sfcc
arburt Wed, 09/26/2007 - 22:35
hey marc,
check your rsa key pair using
6.x show ca mypubkey rsa
7.x show crypto key mypubkey rsa
also check the versions running using show ssh
if you changed the domain name, zeroize then
then regenerate a new RSA key pair
post your OS version so we can check it for bugs.
drumrb0y Thu, 09/27/2007 - 03:06
Thanks for the reply;
I have yet to successfully connect with ssh, so I haven't even established a key pair yet; to be thorough, I deleted all keys off of my ssh client, then zeroized and regenerated keys on the ASA.
Sh ver: 7.2(1)
DR-ASA1# sh ssh
Timeout: 60 minutes
Versions allowed: 1 and 2 (my ssh client can run both) flr inside sfcc (connecting to)
The error I get when trying to connect is that the host is unreachable, but I can ping the interface fine. The problem might not be the device, but I wanted a second opinion that it isn't.
arburt Thu, 09/27/2007 - 20:49
try to do an ssh debug, to check if the session is really hitting your pix.
also, check if the ssh client is behind a firewall and if ssh is not permitted
