09-26-2007 05:31 PM
Hello to all,
my 3005 concentrator has many IKE proposals opted, but the 3002 client is not matching up on any. Here is a sample of the 3005 concentrator event log -
9375 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52540
Proposal # 1, Transform # 17, Type ISAKMP, Id IKE
Parsing received transform:
Phase 1 failure against global IKE proposal # 1:
Rcv'd Key Length attr class, but class is not cfg'd
9379 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52541
Phase 1 failure against global IKE proposal # 2:
9381 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52542
Phase 1 failure against global IKE proposal # 3:
9383 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52543
Phase 1 failure against global IKE proposal # 4:
9385 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52544
Phase 1 failure against global IKE proposal # 5:
Mismatched attr types for class Key Length:
Rcv'd: 256 Bits
Cfg'd: 128 Bits
9388 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52545
Phase 1 failure against global IKE proposal # 6:
Rcv'd: 256 Bits
Cfg'd: 128 Bits
9391 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52546
Phase 1 failure against global IKE proposal # 7:
Rcv'd: 256 Bits
Cfg'd: 192 Bits
9394 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52547
Phase 1 failure against global IKE proposal # 8:
Rcv'd: 256 Bits
Cfg'd: 192 Bits
9397 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52548
Phase 1 failure against global IKE proposal # 9:
Mismatched attr types for class Hash Alg:
Rcv'd: SHA
Cfg'd: MD5
9399 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52549
Phase 1 failure against global IKE proposal # 10:
Mismatched attr types for class Auth Method:
Rcv'd: Preshared Key
Cfg'd: XAUTH with Preshared Key (Initiator authenticated)
9403 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52550
Phase 1 failure against global IKE proposal # 11:
9405 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52551
Phase 1 failure against global IKE proposal # 12:
9407 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52552
Phase 1 failure against global IKE proposal # 13:
9409 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52553
Phase 1 failure against global IKE proposal # 14:
9411 09/26/2007 20:17:41.800 SEV=8 IKEDBG/79 RPT=52554
Phase 1 failure against global IKE proposal # 15:
Rcv'd: 256 Bits
Cfg'd: 128 Bits
Thanx for any help!
10-03-2007 01:48 PM
The VPN 3000 Concentrator might not decrement the Simultaneous IKE counter correctly while under a very heavy load of incoming IKE sessions. Can you please send error message and also client configuration. Without this information it is very difficult to find accurate solution?
