Avaya VoIP behind 871 with NEM
Sep 26th, 2007
I'm having trouble getting my Avaya IP agents working behind an 871 router in NEM mode. They are connecting through a vpn3000 concentrator. Everything works as expected such as RDP, ping, ssh, etc.
Here's the config
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname <removed>
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console alerts
enable secret 5 <removed>
no aaa new-model
clock timezone EDT -4
clock summer-time EDT recurring
crypto ipsec client ezvpn <removed>
connect auto
group <removed> key <removed>
mode network-extension
peer <removed>
xauth userid mode http-intercept 401
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.31.200.9
ip dhcp pool sdm-pool1
network 172.31.200.8 255.255.255.248
default-router 172.31.200.9
dns-server 172.31.200.9
no ip bootp server
username <removed> privilege 15 secret 5 <removed>
username <removed> secret 5 <removed>
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 172.31.200.9 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
crypto ipsec client ezvpn <removed> inside
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server view-group ezvpn-internal-viewlist
ip dns server
logging trap debugging
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
scheduler max-task-time 5000
ntp source Vlan1
ntp server <removed>
webvpn cef
end
