IPCCX 4.0 Work Flow Launch External Application
Sep 26th, 2007
Has anyone used the work flow action - launch external application to call 3rd party apps with parameters?
I am trying to lauch an application and to use the ANI as the last parameter but the ANI is preceded by a space from the system and proves to be a problem for my appliction to get a valid parameter. Is this normal? Is there anyway i can remove this space character?
Abdulbaseer Mohammed Thu, 09/27/2007 - 10:01
how are you passing the ANI, you can eliminate space using dynamic or defined label.
if you share your script and version probably some on can help.
