CSA (Access problem)
Sep 26th, 2007
Actually I m able to log in the CSAMC, but can't access the database or any other things.Plz help me asap.
ivillegas Wed, 10/03/2007 - 13:55
Find whether CSAMC service was disabled .Once CSAMC service get start again, then restarting CiscoWorks Daemon will start CSAMC
tsteger1 Wed, 10/03/2007 - 14:39
Hi Santu, you didn't mention what version you are running. If you can get to the MC, the service is running.
Check the csamclog.txt for db connection or other errors.
If it's a local db, is the SQL instance up and running?
If remote, is the server and db up and running?
