857W "Unnamed Network"
Sep 26th, 2007
Hi Gurus,
I have just setup my new 857W, I have Wireless working no problems.
But I was wondering why I have 2 "networks" that I can connect to when I go to "Connect to a network" In Vista?
I have the SSID displaying that I setup, no worries there, but I also have "Unnamed Network" as well, which is definitely coming from my router because they both disappear if I shutdown the interface - and I can also connect to it.
Have I done something wrong, or is there something I have missed?
Also have I configured this correctly using dot1q even though I only want one SSID, or is there a better way I should be doing this?
Cheers.
IOS version is 12.4(15)T1
Config:
dot11 ssid mynet
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 7 blah
information-element ssidl advertisement wps
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
ssid mynet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
Anonymous (not verified) Thu, 09/27/2007 - 02:49
Not sure what's happening with my name / account, apologies.
Anonymous (not verified) Fri, 09/28/2007 - 00:45
I worked it out - all I had to do was enable "guest-mode" on the ssid and now I do not see the "Unnamed Network".
