ASA management through VPN
sajin
Can ASDM be accessed through VPN. I configured the following commands.Didn't work.
username xxx password xxxx encrypted privilege 15
username xxxx attributes
vpn-group-policy xxxx
vpn-framed-ip-address 172.16.1.250 255.255.255.0
http server enable
http 172.16.1.250 255.255.255.255 inside
management-access inside
srue
Level 7
Level 7
can you telnet/ssh to the inside interface over the same vpn connection?
6 Replies 6
srue
Level 7
Level 7
try...
http 172.16.1.250 255.255.255.255 outside
it definitely needs to be on the 'inside' interface.
make sure the inside interface is part of the general vpn set up.
u cant specify management interface as outside. So it should be some thing other than outside.
I was trying to use VPN behind ASA (remote) .Later from home when i tried it started working. Can u tell me what all ports has to be opened for using vpn behind firewall.
Kevin Xiong
try a different port other than https:
example:
http server enable 4433
once AVC establish the SSL-VPN, connect ASDM to ASA-inside-IP:4433
you may need to enable/disable http a couple of times:
no http server enable 4433
