smothuku Thu, 09/27/2007 - 01:20
  • Silver, 250 points or more
Hi ,
It willn't impact u r network ..You change the hostname.
satish
Richard Burts Thu, 09/27/2007 - 02:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Adetutu
As far as layer 2 forwarding is concerned I agree with Satish that there is no impact from changing the host name. There are some other aspects which may or may not impact depending on your particular situation. If you have the switch configured for SSH (which requires RSA keys) changing the host name will invalidate the RSA keys and SSH will not work until you regenerate the keys. If you have the switch defined in DNS then you should update the DNS. If you have any network monitoring or reporting set up using device names then you probably need to make some adjustments there. But as far as traffic forwarding in your network is concerned there should be no impact from changing the host name of a switch.
Rick
