MUHAMMAD SHAHEEN Thu, 09/27/2007 - 03:34
  • Silver, 250 points or more
The interconnecting link between both switches which are casecaded is called uplink.
Shaheen
Joseph W. Doherty Thu, 09/27/2007 - 04:04
Say you had to interconnect 5 switches.
If switch A connects to switch B which connects to switch C which connects to switch D which connects to switch E, this is a cascade.
If switches B through E each connect only to switch A, you would refer to the connections on switches B through E as uplinks and conversely the same connections on switch A to all the other switches as downlinks.
