bri configuration
Sep 27th, 2007
please i have customer need to implemnt ccme and make voice call through bri VIC2-2BRI-NT/TE so please i need any example of configuration or any websites that talk about how to configure the bri port and the dial-peer
paolo bevilacqua Thu, 09/27/2007 - 03:19
  • Hall of Fame,
    Founding Member
Do you have multiple BRI or a single one ?
If multiple BRI, put them under trunk-group and reference it as destination for DP.
The needed configuration would then be:
interface BRI0/2/0
no ip address
no logging event link-status
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn tei-negotiation preserve
trunk-group my-trunk
voice-port 0/2/0
no vad
compand-type a-law
mostafamossad Fri, 09/28/2007 - 02:52
please can u send for me a complete configuration or any refrence explain the configuration
paolo bevilacqua Fri, 09/28/2007 - 02:55
  • Hall of Fame,
    Founding Member
There are too many variables involved for sending complete configurations and hope that it will work.
If you have never configured CME, do the telephony-setup wizard, if you have problems explain here and someone will try to help.
mostafamossad Fri, 09/28/2007 - 03:25
i need also to know how can i determine if i need to configure the port in the network mode or in the terminal device mode
