urgent acs 4.0 failure
Sep 27th, 2007
hi,
i have installed acs 4.0 lately on windows 2000 sp4, i had before acs 3.3 working perfectly,
with acs 4.0 sometimes if i hit the User Tab, it freezes and all services don't work anymore (csauth,csadmin,csradius), i can't restart them i need to restart the server to go back to normal.
is this a bug ? any workaraound
Jagdeep Gambhir Thu, 09/27/2007 - 04:25
  • Red, 2250 points or more
I would suggest you to upgrade acs to 4.1 as current code have lots of issues related to services.
Most likely that will fix it.
~JG
