CRC ERROR ----- WHY ???-----
Sep 27th, 2007
Hi all,
I am facing the crc error with some one switch... I did verifed the L1 (connections, power etc...) this are okay.
After of verify all this, I did a test disabling (disconnect cable) the port and clear the counters, but the port continuos the increase "CRC ERROR".
Someone Known why IS this happeing???
Probably thi problem on switch, but why????
Kevin Dorrell Thu, 09/27/2007 - 04:21
It is still counting with the cable disconnected? Surreal!
The only thing I can think of is that it might be being used as a reflector port for an RSPAN session.
What model of switch is it? Can you show us a show run and a show int for the port?
Kevin Dorrell
wimccall Sat, 12/22/2007 - 15:07
Disconnect the cable and paste the sh int for that interface. The interface may be dead.
