l.mourits Thu, 09/27/2007 - 04:34
  • Silver, 250 points or more
Short answer:
No, not possible, at least not from the switch
Long answer:
Not possible from the switch. However, you can configure syslog or SNMP traps on the switch and have the syslog or SNMP trap server send an email on specific alerts.
HTH,
Leo
mirtenmous Thu, 09/27/2007 - 04:51
Where can I see all SNMP commmands available in my 3750 switch with Version 12.2(25r)?.
Do I need any more infraestructure to run SNMP from the switch?.
JORGE RODRIGUEZ Thu, 09/27/2007 - 05:16
  • Green, 3000 points or more
Hi Andres,
when logged into switch config mode simply
issue " snmp ? " which will display all snmp sub-commands. Check the link provided for seting up snmp , the only infrastructure addition you would need is seting up a snmp server machine so the switch can send snmp traps to the server for analysis.
seting up snmp
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swsnmp.html
Also there are some monitoring software you could use for collecting snmp information and port utilizization grapher, software such as ciscoworks , you may try some freeware MRTG or PRTG, PRTG easy to setup on windows.
you could try prtg
http://www.paessler.com/download/prtg
or mrtg freeware
http://oss.oetiker.ch/mrtg/
you may also try kiwi syslog real time port state monitoring, or whatsup gold that allows email notification based on port status.
http://www.ipswitch.com/products/whatsup/index.asp?engine=google&cat=wug&k_id=goldprem&gclid=COrMiMvd444CFQIQFQodNj7VPA
Jorge
