09-27-2007 04:43 AM - edited 03-14-2019 01:21 AM
I'm running CRS 4.0.4 with callmanager 4.2.3. My desktop agents work fine and I was going to use IP phone agent as a backup for anytime a PC is down. When I select the service on the phone I get the error "host not found." I am using the callmanager IP in the service URL and my callmanagers are identified in the callmanager menu on the CCM by their IP addresses. I have restarted the TFTP service and reset the phones. I have the desktop agent closed on the PC while I am trying to login to the phone agent. What else could be causing my problem?
09-27-2007 08:10 AM
Maybe the subnet where your IP-Phone is in can?t reach the Service URL address (port 80).
Or you are using a firewall that is blocking the communication between IP-Phone and Callmanager.
See also:
http://cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a008009463f.shtml
12-13-2007 07:32 PM
I think you are doing mistake, Pls use the IP address of IPCC instead of CCM in the URL, it will work
the link is
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a008029e6d5.shtml
Naga
09-04-2008 05:19 PM
I have similar issue with this same problem on CCM 6.1.2. Make sure that "Update Subscriptions" button is click in order for it to work, Save button will not.
10-09-2008 04:15 AM
Hi. I have installed the IPCC exp on the same server as CCM. so both the ip are same. but still is not working. Host not found error.
any thought from forum friends
gem
10-10-2008 07:25 AM
Hi. It is working now. I have just put ip address of ccm instead of host name of the callmanger in the enterprise parameter URL services. Now it is working fine.
regards
gem
