firewall cisco equipment help
I need to specify a firewall capable of 100Mbps throughput and that support QoS
Ive been advised the following products- but they are vast price diffrences --
can i ask which would be the best solution and why
the PIX515E-UR-BUN , but then I looked a the cost compared to ASA5505 or ASA 5510 which is a fraction of the cost ?
j.beckner Mon, 10/01/2007 - 08:54
I suggest that you find a Cisco Registered or Certified Partner in your area who can help you. Go to and click on the Partner Locator link on the right side under Quick Links. I'm a registered partner in the San Francisco area but you are in Kingston (Jamaica?), so you are out of my service area. I've always wanted to go to Jamaica, I'm a fan of Reggae music.
Trending Topics - Security & Network
