Call Control Group Override
Sep 27th, 2007
Is there a way to override the Display variable in the Call Control Group based on a parameter such as DNIS? Also, can I override the Hold Music Source? The TAC Engineer that I was talking to said he thinks this is possible and I'm waiting to hear back, but I wanted to send this to the forum. Thanks!
Abdulbaseer Mohammed Thu, 09/27/2007 - 22:14
  • Silver, 250 points or more
Yes yes.
Instead of using hold step you can try playing your music or wav file as a prompt with interrupt enable.
Hope that helps.
Baseer.
