create user group to authentication to ACS for ASA SSL VPN 8.0
Sep 27th, 2007
need some advice on how to implement the following requirements
To create a group users(policy) to specific URL that is authenticated to ACS 3.1 via radius. The ACS 3.1 synchronised with AD. the group user will be the AD group.
Can i use LDAP authentication for asa ?
Appreciated if anyone can help
amritpatek Wed, 10/03/2007 - 18:13
I don't think it is possible to specify a URL that can be authenticated to ACS, although you can define a group policy for users that need to be authenticated to the ACS. You can use LDAP authentication for ASA. By default, the security appliance auto-detects whether it is connected to a Microsoft or a Sun LDAP directory server. But, if auto-detection fails to determine the LDAP server type, and you know the server is either a Microsoft or Sun server, you can manually configure the server type. Followig link may help you regarding LDAP configuration
http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/selected_procedures/asdmldap.html#wp1033196
