1242AG - WPA Without RADIUS
Sep 27th, 2007
Hi all, im trying to configure an access-point model 1242AG with WPA, but i dont have a RADIUS server, and i didnt find any doc about how to configure it with WPA-PSK, is it possible? in the documentation in this link
"If you select EAP Authentication or WPA, enter the IP address and shared secret for the authentication server on your network."
But i dont have RADIUS.
Is it possible to use WPA without radius with 1242AG?
Overall Rating: 5 (1 ratings)
bcolvin Sat, 09/29/2007 - 10:49
The short answer is yes, the long answer is it is not obvious
First using the GUI interface go to Security-Encryption Manager and select Cipher then TKIP from the drop down,dlick apply, you are done with this page.
Second select SSID manager,in this window select your SSID then go to the Authenticated Key Management frame select Mandattiry and check the WPA box. type or paste your WPA key in the WPA pre-shared key box. click apply, you are done
this is the link for the configuration
Good luck
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
