Reserving Timeslots on a ISDN PRI
Sep 27th, 2007
Can it be configured on the ISDN PRI link of the Central Location Data Center, reserving 10 Timeslots for taking the calls from one particular Branch Location and another 10 from another individual branch and remaining 10 from left over Branch Sites.
Can we use the channel-group command for this type of the configuration.
Can the 15th timeslot (for e.g., Serial 2/0:15) used when reserving the timeslots under the channel-group command.
Request anyone help me finding a solution.
Keshava Raju
[email protected]
paolo bevilacqua Thu, 09/27/2007 - 14:02
  • Hall of Fame,
    Founding Member
You cannot partition the PRI and if you want to limit calls, it's particularly complicated because what you want to do, is to not answer or reject calls when the group a branch pertains to, is full.
In my knowledge, this is not possible. You can hack something with radius to do that authentication is denied when group is full, but this is not the same as not taking the calls.
