AVS 3120 booting maintenance image
Answered Question
Sep 27th, 2007
Dear friends,
My AVS 3120 box is booting, by default, the maintenance image. How can I configure it so it boots the production image whenever I reboot it?
Thanks!
Correct Answer by irisrios about 9 years 3 months ago
Try these steps login into the system, switch from the cli prompt to shell prompt ( using sysopen) , login as root ( su - ), execute the command ( /usr/avs/appliance/bin/switch_grub.sh avs) Now the boot order should be reset to the default boot order.
Overall Rating: 5 (1 ratings)
Correct Answer
irisrios Thu, 10/04/2007 - 09:52
