Real time and Historic Reports
Overall Rating: 4 (1 ratings)
Abdulbaseer Mohammed Thu, 09/27/2007 - 22:08
  • Silver, 250 points or more
It all depends where and how you are pulling reports. No the same line should not have any effect.
Also if your script is such that it does not have proper end or transfers then call me look abandoned so it depends on your call flow as well.
Check your script and your location where you are counting calls.
If it helps please rate.
BAseer.
