CallManager 5.1 remote shutdown procedure
Sep 27th, 2007
We have just deployed centralized UPS solution but starting with Linux Appliance there is no possibility to install UPS agent under OS. We've tried to make script and execute "utils system shutdown" command from Windows using SSH and PuTTY, but unfortunately that doesn't work. If someone have experience with such procedure, I'll really appreciate that. Thank you.
richard.leclerc Tue, 10/02/2007 - 06:06
We have the same problem here but we managed to shutdown one server using an Expect script under Linux workstation. Unfortunately, we can only shutdown one server (Publisher).
We are not able to shutdown the subscriber when the UPS agent start the script. If we start the script manually, we can shutdown both servers. We are still looking to find a solution that works for multiple servers.
