2nd Ip helper address
paolo bevilacqua Thu, 09/27/2007 - 14:06
  • Hall of Fame,
    Founding Member
Yes. B'casted packets will be duplicated and routed to all helper addresses.
paolo bevilacqua Thu, 09/27/2007 - 14:17
  • Hall of Fame,
    Founding Member
Yes, if you want. Some network has so complicated helper hierarchies that spanning-tree is needed to not duplicate paths. Apparently IOS can do that.
Jon Marshall Thu, 09/27/2007 - 20:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi James
Just to add to Paolo's points. Rather than think of active and backup DHCP servers just think of both DHCP servers being active. You can split the scope across your 2 DHCP servers so one serves out the first half of the scope and the other serves out the second half of the scope.
Jon
