09-27-2007 04:23 PM - edited 03-05-2019 06:44 PM
what command do i use to remove this line from pix?
static (inside,outside) tcp x.x.x.x smtp mailfilter smtp netmask 255.255.255.255 0 0
09-27-2007 05:20 PM
no static (inside,outside) tcp x.x.x.x smtp mailfilter smtp netmask 255.255.255.255 0 0
hth,
paul
09-27-2007 05:22 PM
yeah that is what i thought and tried and it kept giving me an error
no static then all the info i had in there
09-27-2007 05:38 PM
leave of the last "0 0". If that doesn't work ( it should - I just tested it on mine) reboot the PIX and try again.
hth,
Paul
09-27-2007 05:41 PM
thanks i will try that in the morning, thanks for the help
