IOS Upgrade
Sep 27th, 2007
Hi, I'm trying to upgrade my 803 router that is currently running 12.1 IOS. I would like to upgrade to 12.2-46. I have downloaded the image and transfered it to the device. I have entered the boot system flash:<filename> command, saved the config and reloaded. The router will only Load the 12.1 image (both images are in flash). Is there a step I'm missing? The router has TinyROM 1.0(2), could that need to be upgraded? I downloaded TinyROM 1.14(1), how would I install that? Do i acutally need console access or can I do it remotely? This is kind of urgent, so any help would be greatly appreciated. Thanks!
