2811, PVDM2-16, do I need configure 'flex' to support 16ch?
Sep 27th, 2007
I confiugred T1 timeslot 1-16 and 'show voice dsp' displays 16 channel but nothing configured under 'voice-card 0'
as per doc, 'medium' codec complexity is default and it supports 8 channel.
Do I have 8 channels only since 'medium' complexity by default? If yes, is it mendatory configuring 'flex' to support 16 channels?
Thanks in advance,
Jon Nelson Fri, 09/28/2007 - 17:18
Nothing will show up under voice-card 0 if you are just configuring a T1. The voice-card configurations are used for conferencing, transcoding, and MTP resources.
If you have a PVDM2-16 in your router and the T1 configured for slots 1-16, you are using all available DSP resources. If you want to enable the above resources, you will need to add additional PVDM's to your router.
Thank you,
Jon
