Channelize card or multiflex
Sep 27th, 2007
For a PRI, can someone clarify when to use a NM-HDV2-1T1/E1 with (VWIC-1MFT-T1) over a Channelized E1/T1/IDSN-PRI NM.
Can the Multiflex T1 VWICS with any CAS or CCS signaling?
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 09/28/2007 - 02:50
What router do you have? If an ISR you don't need the NM-HDV2-1T1/E1, the VWIC fits directly and you just need the PVDM2 module for codecs.
