ACL
cmadiam82
Hi!
Im new to ACL's. This is my question. Is ACL will take effect in an interface in a pix even if this ACL is not used in a access group command?
example:
access-list inside_access_in permit ip any host CFS016
Just like that. Co'z i can't find any access group that use that ACL.
tnx!
ajagadee
You need an access-group command to bind the access-list to the interface.
Before you remove the access-list from the configuration, check and make sure that the access-list is not used somewhere else other than the interface. For example, you could use the above mentioned ACL under crypto map for the interesting traffic.
name 1.1.1.1 CFS016
crypto map TEST 10 match address inside_access_in
I hope it helps.
Arul
